Autoindexing a map crashes LV64
I'm using the new map functions in LV2019. They seem to work fine in the 32 bit version but crash the 64 bit version.
CLED (2016)
(2,716 Views)
I opened and ran your vi in LabVIEW 2019 64-bit (19.0f1).  I didn't get any crashes.
(2,568 Views)
Thanks for testing. I was running 2019. I checked the update service and didn't see anything so I didn't know about the f1. I upgraded and the crash went away!
(2,542 Views)
Anyone else still get crashes?  When I'm using maps in 64 bit (the maps are actually private data w/in a class) the OS nukes the whole works in an unhandled crash.
LabVIEW 2024 Q4 64 bit.
Faulting application name: FATS.exe, version: 0.0.0.209, time stamp: 0x66f3ffc8
Faulting module name: lvrt.dll, version: 24.3.2.4002, time stamp: 0x66f40077
Exception code: 0xc0000005
Fault offset: 0x0000000000b7c7d9
Faulting process id: 0x0x52E0
Faulting application start time: 0x0x1DB5BA3125089AB
Faulting application path: C:\Repos\TED\Software\FATS\Builds\FATS.exe
Faulting module path: C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\2024\lvrt.dll
Report Id: 0fc5224d-13af-429d-8053-146578402cc8
Faulting package full name:
Faulting package-relative application ID:
I don't think I'm doing anything exotic.  I have the same thing implemented with arrays and never get an issues.  But figure maps are the quicker/more elegant method.snippet 01.png
(652 Views)
