Automate measurement for Keithley 2520
I am new to LabView for instrument automation. I am trying to write a LabView program that will measure the L-I-V characteristics of a laser diode from the Keithley model 2520. There are no instrument drivers for this tool, so I turned to Keithley and found the attached example program. It does not work when I attempt to make measurements. Will I have to write a program from scratch, or am I likely using the example program incorrectly?
Nick
(3,557 Views)
What do you mean "does not work"? Do you get errors, wrong data, fried laser diodes, what?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,540 Views)
What exactly doesn't work? What error code/message do you get?
(3,537 Views)
When I set my desired parameters, I hit the "sweep" button, which then pauses and prompts me to save a file, presumably the collected data. The file is empty and nothing is displayed on the graphs in the VI.
(3,533 Views)
