Automatic OCR Taining
Hi guys,
I come from Germany and I´m new in this community. I hope you can help me. My question is: Is it possible to built an OCR which can train a letter atomatically? Actually I train with the Visual Assistant every letter manually. At the end I will build a system which uses an OCR on a whole text.
I hope you unterstand me and can help me.
(2,497 Views)
Hallo
It is required to train all characters and generate a .abc file which contains the trained data. I came across some posts that show how to train characters programmatically (can make our work easier). Refer the below links.
https://forums.ni.com/t5/Example-Programs/Programmatically-Train-IMAQ-OCR-Characters-using-LabVIEW/t...
https://forums.ni.com/t5/Example-Programs/Programmatically-Generate-an-Optical-Character-Recognition...
Hope this helps.
-Rahul
Hit KUDOS for Thanks
(2,445 Views)
