Automatic error handling
So far I always kept the Automatic Error Handling (AEH) on for my VIs. My thought process was that
- IF I made an error in programming by not terminating all my error cluster
- AND an error occurs
- THEN I'd like to display it otherwise the error remains silent and I wont have an idea that it even occured
Today I have realized that the VI analyzer throws an error if I have the the AEH. That made me thinking but the only thing came to my mind is having a popup could be dangerous in some situation as it stops the VI execution. I still rather back having the AEH on cause yes it can drop a popup, but not having a popup keeps the error hidden and also could lead a potentially dangerous situation. If we are at the brink of a situation then I prefer to - at least - know about the error.
Could be that I missed something or I dont evaluate the risk properly so I'm wondering if there is a consenus about this subject. Do we need to use automatic error handling in our VIs, or should we turn it off? (forget RT for now which doesnt support it)
Thx.
Message 1 of 15
(3,998 Views)
Hi 1984,
IMHO:
  • Your program should handle any errors on its own. Never leave an error wire ending in the open wild…
  • Even when you don't "handle" an error you should log that error: create a small "error log" subVI as a starter…
In my early LabVIEW days I was biten by such AEH dialogs as the remaining program might be blocked. That's why you should (IMHO) switch off the AEH once and for all!
Message 2 of 15
(3,995 Views)
Thanks for responding.
True, but if we wire all the error outputs then my question doesnt make sense as in that case the AEH has no effect. My question is rather which one is the lesser evil. A popup which could lock your app or a possibly unnoticed error causing unexplainable problems? Now as I write it down, this seems more of an application specific decision.
Absolutely, but thats again assumes that the programmer connects all the error clusters.
Message 3 of 15
(3,953 Views)
Hi 1984,
It's very app specific!
When you app "just" reads in some data files and does some number crunching then an error dialog like "file not found" may be appropriate. When the app controls a big testbench with several safety-related control loops then it might get problematic, when an error dialog blocks UI interaction…
Yes, it's the programmer that is responsible for its work…
Message 4 of 15
(3,949 Views)
One vote here for automatic error handling on during development is that it allows you to put probes on your wires.
Bill
CLD
(Mid-Level minion.)
Message 5 of 15
(3,940 Views)
Hi Billko,
@billko wrote:
…automatic error handling on … allows you to put probes on your wires
Could you explain how using probes is related to AEH?
Message 6 of 15
(3,923 Views)
I can't reproduce it in LV 2018, but I've seen in LV 2020 that if you have AEH turned off, your probes will say "No debug Info" and they won't work.  BUT, I only have one copy of LV 2020 and the code resides on a computer where I am not allowed to share code from.  In that environment, in order for probes to work, you have to enable AEH or they are just grayed out with "No debug info" where the probe data would normally be.  This consistent throughout all the VIs already made, and any future VIs that are made.
Bill
CLD
(Mid-Level minion.)
Message 7 of 15
(3,912 Views)
Automatic Error Handling should have no effect on probes. If you can reproduce the probe issue you describe, please give me detailed instructions on how to do so. I have used LabVIEW 2020 as my daily driver IDE for the past 2.5 years, I have AEH turned off on all my code, and I've never had a problem with probe functionality.
To reply to the OP, there is a contingent of LabVIEW programmers who feel that AEH is a crutch and hinders LabVIEW programmers from putting proper thought into the error propagation that takes place in their VIs. I fall into this camp, I added that VI Analyzer test, and AEH is one of the many topics I discuss in my What to Expect When You're Expecting an Error presentation: http://bit.ly/dnatterrors
If you don't agree, that's fine... just deselect the Auto Error Handling Enabled VI Analyzer test in your configuration.
Message 8 of 15
(3,884 Views)
I fall into the same camp as you Darren. The application should always include proper error handling. By doing so you put more thought into the design and code and in my opinion end up with a better more robust application as a result of it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 15
(3,838 Views)
I also have to agree that error handling is program and error specific there is no one way to handle errors.
In general on an error you should:
  1. Put the UUT into a safe state (Shut down power sources etc.)
  2. Log the error and some debug info
  3. Halt the program
  4. Display an error message
But in the case of communication errors:
  1. Ignore / clear the error
  2. Retry communications a few times
  3. If that fails
  4. Put the UUT into a safe state
  5. Log the error and some debug info
  6. Halt the program
  7. Display an error message
=== Engineer Ambiguously ===
Message 10 of 15
(3,827 Views)
