Automatic saving labview data
here is one autosave example vi I wroteSmiley Happy
Message 11 of 15
(2,971 Views)
hi
sorry but I can not open.
my version of labview is 12
Message 12 of 15
(2,962 Views)
Accepted by topic author Saille
Okay, try this one
Message 13 of 15
(2,947 Views)
thank you very much, also works..
but now
I have 10 files in  ".txt"  in a folder, they are parts of a single aquivo
 how do I group all 10 files and form only a ".tx"t file?
thanks
obs: My idea is generally several small files and then save them, theoretically it would not slow the program .. it saved large amounts of data
Message 14 of 15
(2,941 Views)
Hm then I would then use TDMS
format. This is better for multi chanel
bigger data.
If you want to stuff it into one txt File
you have to think more about the format.
Very often used is for example csv
that is actually a txt format where
one can store column wise data.
Then you woud take my example and
let it write to the same file over and over
agin with the append mode.
Ok so far for now - weekand is aproaching!
regards
andreas
Message 15 of 15
(2,927 Views)
