Automatic tool. Do everyone use it?
Hi all:
Well, now I'm confused... I can't remember in which release started Automatic Tool. I think it was LV6.1... may be too late to post this, but, anyway.
I remember I went to a 4 hour demonstration of the new release, and the very best thing of the release was the Automatic Tool.
I give it a try that day. But didn't make it. I didn't felt it was an improvement, as with TAB and SPACE I knew all the time which tool I was using, and with Automatic Tool I needed to move the mouse slowly, see whick tool LV chosen for me, move again, ok, this is... now... ooops, changed again!!
So the first thing I do in a fresh LV instalation is to set it to be off.
I see some posts that are very confortable with it, and that they really use it.
Please, should I give Automatic Tool another try?
Thanks in advance,
Aitortxo.
Message 1 of 37
(7,359 Views)
The Auto Tool rocks.  I admit it takes some getting used to.  And I definitely turn off the Auto Tool locking feature in Tools > Options (in case I do need to Tab or Space).  In the rare circumstance where I need some tool behavior that the Auto Tool doesn't readily provide, I just shift-right click to bring up the Tools palettes and just keep going.  Plus, the auto tool seems to get a little smarter with each LabVIEW release.
And just so y'all don't think I'm biased, there are NI people who disagree...one of my teammates, in fact, who is an old-school LabVIEW guy, hates the Auto Tool and has never switched to using it.  But whenever I occasionally need to use an older, pre-autotool version of LabVIEW for whatever reason, I feel totally crippled having to Tab/Space every time I need a new tool.
You should find that after you get used to it, the Auto Tool speeds up your LabVIEW programming tremendously.
-D
Message Edited by Darren on 03-15-2006 05:17 PM
Message 2 of 37
(7,336 Views)
Absolutely!  Use it 99.9 % of the time.  The only time I go manual is to change text color.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 3 of 37
(7,329 Views)
We may be the only four people in this community who use it.  I love it.  Everyone else I talk to hates it and turns it off.  They like pressing the Tab key.  I hate pressing the Tab key.
- tbob
Inventor of the WORM Global
Message 4 of 37
(7,328 Views)
I guess I belong to the old school.  Never liked it.
-Khalid
Message 5 of 37
(7,311 Views)
Oh yea!
When the auto tool first came out, it was a bit unpredicatable, but for the last couple of LabVIEW releases it has been stellar. I never turn it off.
Message 6 of 37
(7,312 Views)
Automatic tool is great and very time-saving.
Luckily, I started developing with it, so I didn't need to manage the transition, but in any case I would never stop using it.
My suggestion is to try again!
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 7 of 37
(7,301 Views)
I think it works great and is almost never wrong. I love it. It does get to be tricky when handling elements which are close together, but that's understandable and it is almost the only case (other than changing colors) where I actually need to change a tool manually.
The trouble is that since this way you almost exclusively need just one hand for programming, I sometimes find myself too lazy to release the second hand from whatever it's doing, so I start doing some select->edit menu->copy->go elsewhere->edit menu->paste action and similar things instead of the ctrl+C->ctrl+V sequence. I usually figure out pretty quickly that it's better to free up the other hand.
___________________
Try to take over the world!
Message 8 of 37
(7,302 Views)
I also like the way in which it allows you to drop a comment simply by double clicking in an empty space (something that doesn't always seem to work properly in nested structures, at least in 7.0).
___________________
Message 9 of 37
(7,298 Views)
I can't work with that automatic tool... to be perfectly honest I haven't really tried, I am used to the 'tab' and 'space' keys and don't feel I'm loosing time.
I was thinking it is just rubbish but concidering that so many confirmed wire-worker outhere love it, I assume it just requires a short time to get use to it...
De gustibus non est disputandum 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 10 of 37
(7,295 Views)
