Automatic update on references
I have a reference on a cluster. This reference is use to restore parameters in a files. I use it with a property node. When I do modification in the cluster (that is strict type def) the reference doen't update, so my application doesn't compile. What can I do to make the reference update with the cluster?
Thank you.
(2,854 Views)
Are you using the reference in a subVI? If so, click on its terminal and check "Include Data Type". The property node should now say (Strict).
___________________
Try to take over the world!
(2,838 Views)
