Automatically close panel after run
Hi there,
I have designed a simple labview program, and compile that to a .exe file.
Whenever i had finished running the program (exe), the front panel is
still there. I have to click on the x box on the right top corner of the
window
of the panel to manually close it. How can i close it automaticcally ? I
just
want to quit the program completely after run.
I had tried checking the "Closed afterwards if originally closed" option
in
the VI setup of the program, yet not working. Also tried use the "Quit Labview"
subvi in the application control pallete, not working too.
Any idea will be greatly appreciated.
Rgds,
anthony
(4,244 Views)
>window
>just
Try "Quit LabView.vi". It's located under Application Control.
This vi quits the runtime engine of the LabView exe.
Good luck,
Andreas
(4,244 Views)
Hello Anthony,
the
> window
Try opening a VI Reference (Application Control->Open Vi Reference),
connecting it to a Property Node (Application Control->Property Node)
and choose the item Front-Panel-Window->Open. If you wire a false to it,
the Vi referenced by "Open Vi Reference" will be closed, otherwise it
will be opened.
Bye, Alexander
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,244 Views)
