Automatically create checkboxes and fit to window
Is there a way to automatically increase the number of check-boxes that appear on a user input dialog box?
This is what I am trying to accomplish:
  • Read in an array of strings
  • Create checkboxes based on the array size and fit to window (similar to express vi)
ThanksNAdvance
FredFred
(4,019 Views)
Accepted by topic author FredFred
You can make a custom vi popup, I would convert the array of strings to an array of clucters where the cluster has a check box and a duplicate string.  Then show the number of rows of the array = number of elements.  Then you can programatically size the window with property nodes.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,010 Views)
No quickdrop in LV8.2, so my coding is too slow.  Do what he said.
(4,005 Views)
One slight change to the cluster, I would either put an clear decoration over the string control or disable the string control (property disable = 1) to prevent the user from typing on the string control.  I use this disable trick to make the appearance of clusters that are controls and indicatiors (eventhough ther are really all controls)
Paul Falkenstein
(3,996 Views)
Thanks to both for the response.
This is a good starting point for me...but...my array is a large one (about 50 contents) and would like to stack them in a 2D array fashion.
Will continue workign that issue and post anything once I figure it out!
Thanks for the help
(3,966 Views)
I also need to display one column as check box in a 2d array.
May I know if you have any suggestion, thanks.
(3,715 Views)
