Automatically cycle through radio button selections
I’ve been searching through the forums but I haven’t found a solution to the problem that I am experiencing. In my VI, I am communicating to a hardware device which is actually quite straightforward. I’ve managed to get the communication link up and running, but now the problem comes about. In the VI, there is a radio button which has three different options. Depending on which one is selected, the value that is in that x,y location will be sent to the serial device. I can manually cycle through these positions for alignment but once everything is set into place and aligned I would like to be able to automatically cycle through the positions at a certain frequency. Any suggestions?
George
(3,334 Views)
(3,333 Views)
This would be a piece of donut if you wrote this as a State Machine.  You could set the active camera control using a Local Variable...
Jim
(3,288 Views)
