Automatically swith the NI 9481 relays
Hello I am using the DAQ NI 9481 instrument and I am trying to automatically swith the relays on for 30 seconds and then off, however, I can't seem to get this going without manually using a boolean control.  I have tried using shift register examples but they never transfer the true of false signal.
(2,901 Views)
SWITCH*
true OR false signal*
(2,888 Views)
You have obviously done something wrong in your code but unless you post it, how can anyone tell you how to fix it?
(2,884 Views)
Here's what I have so far.  NI cDAQ is the main VI and Relays Port is the SubVI.
(2,870 Views)
