Automation Refnum Constant Not Saving Reference to ActiveX
I am currently using 32bit LabVIEW 2017 on a Windows 7 machine. I have an automation reference constant that I am using to connect to an activex dll that was provided me by a camera company. If I right click and choose select ActiveX class and then Browse I can't find my activex library in the list. If I click Browse again, I can manually find my dll file. I then click ok a couple of times and I test my application and it works as expected. I then close my project and LabVIEW. If I reopen LabVIEW and my project and find my VI that contains the Automation Reference, the reference is no longer connected to the desired dll ActiveX. Is there something I can do to get this connection to save? The current process is, every time I come to change this program and rebuild it, I have to remember to come and reconnect the reference by hand. Any help would be greatly appreciated. So far I have tried registering the dll with windows using the regsvr32 command. Windows tells me I have successfully registered the dll but the above behavior continues. I haven't been able to find any other way of calling an ActiveX in LabVIEW other than the Open Automation VI which exhibits this behavior.
(2,720 Views)
Is your Win7 installation 32bit or 64bit?  Is the DLL a 32 or 64 bit DLL?  How did you register the DLL because the process is different for 64bit.
aputman
(2,690 Views)
