Automation Refnum -invoke node- WinSpec32 Problems
Hello, I am running the winSpec.exe as administrator , but when i try to call the .exe through the automation refnum , the vi is not executing. I have attached the snips of the errors.
(3,447 Views)
Show us your VI.
Also to not waste other people's time:
here are your other posts about the same topic
https://forums.ni.com/t5/LabVIEW/How-to-interface-Princeton-instruments-spectrometer/m-p/3712139#M10...
(3,420 Views)
am not wasting your time ! you dont need to answer if your not interested ...
I have talked with the PI ! I am just trying to solve the problem !!!!!!!
(3,412 Views)
If Princeton Instruments is unwilling to help, you are out of luck.
You are wasting people's time when you keep posting the same thing.
(3,410 Views)
