Automation of Agilent E5071C
I would like to automate Agilent E5071C ENA series network analyzer using labview. I could not find any drivers for the corresponding equipments. Could you please tell me how to go with it?
(3,318 Views)
There are links on the Instrument Driver Network on how to create your own driver. You also have the option of using the Instrument I/O Assistant. Both will require a thorough understanding of the programming manual for the instrument. Agilent has an IVI-C driver for it and you can also use that. The link above has information on IVI.
(3,317 Views)
I have worked with Agilent network analyzers extensively.
They require reading the manual to understand how they work.
Even if there were driver VIs, they will only get you so far.
(3,300 Views)
HI
I am working with an ENA and with labview, when inserting the initialization VI I have an error since the ENA ports are disabled, what could be the cause of that error
(1,421 Views)
