Automotive Diagnostic Command set
Hola que tal:
Alguien sabe la ruta en que se instala la librería
Automotive Diagnostic Command Set Toolkit
Instalé la versión 21.5 pero no encuentro nada en la siguiente ruta C:\Program Files (x86)\National Instruments\LabVIEW 2016\examples
(1,793 Views)
Hi Jhonathan,
@JonathanRomanMQ wrote:
Hi how are things:
Does anyone know the path where the library is installed?
I installed version 21.5 but I can't find anything in the following path C:\Program Files (x86)\National Instruments\LabVIEW 2016\examples
You know this is an English speaking forum and so you reach a broader audience when posting your questions in English!?
General answer:
Each driver only supports the current LabVIEW version (it was made for) and 3 previous versions. So when you install the driver made for LabVIEW2021 it will support LabVIEW 2018, 2019, 2020 and 2021.
It will not support LabVIEW2016!
You need to install a driver version suitable for your LabVIEW version: look out for driver versions made for LabVIEW2016-2019…
(1,776 Views)
Hi Knight Of NI My apoligies for my spanish posting. Thank you very much for your support
(1,761 Views)
