Automotive Engine Simulation library in LV 8.6
I would like to see / use the content of the LabVIEW Automotive Engine Library, but I don't have LabVIEW 2009.
Is it possible to get a version saved for LV8.6 ?
Thanks !
(3,281 Views)
Accepted by topic author Sparc
I saved the AES library for LabVIEW 8.6 .
Regards
Yann C.
France
(3,239 Views)
Thanks !
(3,221 Views)
can you post same for LB8.5
(3,045 Views)
Yes. Note that the library uses Fixed Point representation, instroduced in LabVIEW 8.6. I do not test the library, you may have to change some portion of  code.
(3,005 Views)
