Autopopulate radio button cluster control (and cluster containing checkboxes)?
Any way to auto populate a radio button cluster control and / or cluster containing checkboxes so that the number of radio buttons or checkboxes can be exactly specified?  I expect we can do something simulating this using by starting with an expected maximum number of controls, and then controlling visibility, and selecting autosizing for the cluster.
Sincerely,
Don
(2,834 Views)
Hi Don,
If I did not know you I'd suggest using an array of check boxes in the cluster, but you know this already.
What don't you like about your proposed idea of using more than expected and just showing what you need?
Ben
(2,831 Views)
Well I admit I have been distracted lately what with the Browns not making the playoffs.  Your idea is overall cleaner because you then do not need to know the maximum, and can just unbundle followed by inserting / removing elements as needed. You can have a vertical scrollbar visible to deal with an extensive number. On the practical side, my idea (for the particular implementation of today) will work fine.  Thanks for your prompt response.
I have not had time to do anything more with the skins, 3D graph, and/or picture control yet.  (Many things on the plate.)..Steelers by the way were never the same after that second Browns game although I could not believe how they came back against Jacksonville.  Had they won that game, it would have been one of the great wins in franchise history...Don
(2,826 Views)
Don wrote " Had they won that game, it would have been one of the great wins in franchise history..."
Maybe, there was the "Imaculate Reception" Game.
"Steelers by the way were never the same after that second Browns game "
Boy are you right there! Even if they did beat Jacksonville they would have ended up playing the Patriots tomorow night. Better-off starting "knee-surgery-season" early. My boss said something along the lines of "When the ball is intercepted by someone who's number starts with '6' the season is over."
Ben
Message Edited by Ben on 01-11-2008 08:20 AM
(2,818 Views)
