Autosave file location?
I have my autosave feature set to every 5mins.  I have recently had an error from LabVIEW stating that my file was not a resource file.  Unfortunately i had not committed this into subversion over the previous 24hrs so i have lost my work.
I am wondering if anybody knows where LabVIEW puts the autosave files locally in order for me to recover?  Reading a tip from another thread, i have already checked folder C:\Users\"user name"\Documents\LabVIEW Data\LVAutoSave\Archives and found only zip files dated from 2010.
This surely cant be where LabVIEW is saving as i have been working with this software daily in 2011?
(14,035 Views)
Accepted by topic author Grant_C
Hi Grant,
Your memory locations for both default and temporary purposes can be found by selecting Tools>> Options >> Paths. The autosave option with hich you have set every 5 minutes is for recovery purposes only.
If you regularly save the VI then the autosave folder will appear empty.
I hope that this helps,
Liam A.
(13,997 Views)
