Autoscale for XY Graphs
This is probably a rather simple question, but I am looking for a way to turn on and off the autoscale y scale property of an XY Graph using a property node. Unfortunately I can't seem to find the right property on the property node listings. Has this property been left out or am I looking in the wrong submenu or what?
(2,954 Views)
Go to Yscale/Scale fit. Pass a zero value to disable autoscale, 1 to autoscale once "now", 2 to turn autoscale on. This will act on Yscale n°0. If you have several Yscales, you have first to set the Active Yscale property.
Don't know where you were looking ! 🙂
Chilly Charly    (aka CC)
(2,954 Views)
