Autoscale with stacked chart graph
Hi! I'm trying to set programmaticaly the autoscale (value on 1) on a stacked chart graph (4 stacked plot). Using the property node, I'm able to get it done, but only with the last plot. I'm trying to use "Activ plot" property to get it done also for the 3 others, but no succes so far. Any idea someone? Thanks for your help!
(3,064 Views)
Solved by using "Active Y Scale" instead of "Active Plot" property node.
Could be cleaner:
Regards.
(3,025 Views)
Hi Fwix,
thanks for posting an update, this might help someone in the future.
I'd just like to point out that using the "value" property (or valeur) might at times cause problems with the performance. Best practice is generally to wire the data directly to the terminal.
Pete
Remember Cunningham's Law
(3,010 Views)
