Autoscaling Waveform Graph
How can I set the bounds for the X-axes of an autoscaling Waveform Graph?
Thanks!
(3,622 Views)
An autoscaling Waveform is sort of a vague description since it can autoscale
each axis independently. Assuming the Y scale is the one autoscaling,
you can
use an attribute node to set the Range of the X Scale, in particular the Max
and the Min.
Greg McKaskle
(3,622 Views)
On Fri, 24 Mar 2000 03:44:13 GMT, Greg McKaskle
>you can
>and the Min.
Hi, I've been trying to get results with something like this and
found the Autoscaleing keep getting turned on so when I set my Y
min/max/inc the screen does what I want then the autoscale takes over
and makes the screen do what it wants. I tried to turn it off and
then make it the default but somehow it got set again. These graphs
can be a real bear
to get the results you want.
Steve Drake
(3,622 Views)
Perhaps you missed the atrtibute "X Scale Fit"
It allows you to scale once, always, or never.
Have fun.
Henk.
Steve Drake wrote in message
news:demmdsobl68ps9ck82bkf7enk017gt1p5e@4ax.com...
Graph?
autoscale
> >you can
Max
> >and the Min.
> can be a real bear to get the results you want.
> Regards,
> Steve Drake
(3,622 Views)
