Autosizing front panel proportionally
is there a way to autosize the front panel proportionally? , i have a table when i add rows i want the front panel to autosize with the table. the issue is when the front panel is to small in the bottom the last rows will hide. i dont know if this can be done with property nodes.
note: table 2 is the same size as table 1.
(2,771 Views)
Why don't you add scroll bar to your table instead of trying to resize your FP.  This would be simpler solution instead of making the things complex.
(2,759 Views)
