Auxiliary High power Relay tester project
I am working on Auxiliary High power Relay tester project,for that I am going to use GEN-300-2.5 power supply,i Initialize and configured the instrument by RS232 port but here i have 2 different voltage testing one is 110vdc and 220vdc i am trying to latching by using spdt relay but i am not able do so and i need to measure the time between relay conducting,i am new to labview help me on this one,
(2,394 Views)
How are you controlling the relay?  Post your code and you will get more feedback.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,384 Views)
