Avarage calculation with labview
Hi ago,
your loop stops when everything inside has finished!
Your DAQ loop takes it's time (I suspect something around 45s). When you press stop button, it has probably been read for this while loop iteration, so it affects the next iteration - hence the long waiting time. To stop faster you have to program it so, see attachment for one possibility...
You can also use the conditional stop terminal of the FOR loop (as available in LV8.5), using a case structure is the traditional way.
Edited: As 3 other mention the same thing like me you could believe us agoSmiley Wink
Message Edited by GerdW on 07-07-2008 04:13 PM
Message 11 of 28
(1,741 Views)
thank you a lot friends i tried to do like you but i forget to disable the autoindex,,,,,mamma mia ,,,,thank you a lot now i can measureeeeeeeeeeeeeeeeeeeeeeeeeeee
if i find the button for rating wil do 🙂
Message Edited by ago on 07-07-2008 09:30 AM
Message 12 of 28
(1,727 Views)
Hi ago,
"if i find the button for rating wil do :-)" - you will find those buttons after your first 50 postsSmiley Wink
Message 13 of 28
(1,714 Views)
Hello experts 🙂 the program which we created is fantastic thank you very much
im pimping now my program:-) und I have ragarding this one question:
i want that the date und the time ist in a own column in each row,,, i tried many things but nothing is very logical maybe you can help me,,,,
Message 14 of 28
(1,633 Views)
Hello ago,
well, you could put in another "concat string" and append your measurement results to the date/time string...
You can also:
- index more than one value from an array with the "index array" function
- use the "format date/time string" function to build your date string
(- clean up in general 🙂
Message 15 of 28
(1,620 Views)
Thank a lot for the infos,,, it was succesful
one last question Smiley Tongue : how can I modify my program that the user can only work with it but not change some thing in the program? only the frontpanel should be accessible for the user
Message 16 of 28
(1,593 Views)
hi ago,
you may:
- switch on password protection of the block diagram (as is done in some of the vi.lib functions)
- make an application from your vi (if you have the application builder in your LabView installation)
- save your vi with options and remove the block diagram (don't forget to make a safety backup before - you have been warned!)
I would opt for item 2, as that's the usual way to hand out software to the user - just give them executables, no hazzles with development environment in user interaction...
Message Edited by GerdW on 09-30-2008 03:59 PM
Message 17 of 28
(1,581 Views)
hi guys
i actualy bought and activated the application builder,,,if someone has some suggestion how to create a executable interface please let me now,,,
Message 18 of 28
(1,466 Views)
Hi ago,
Im sure there's some manual you can read!
Well, create a new item in the project explorer, choose "executable" and follw the assistant. Then create another item "distribution" to create an installer - and also follow the wizard...
But: RTFM!
Message 19 of 28
(1,461 Views)
hi gerd thank you for the answer
no NI did only send e code for the activation
i will check the internet for a manual
Message 20 of 28
(1,459 Views)
