Average Value Scope
Actually ı don't know how can ı try with manually . Shoul ı change the attachment vi for it ? or Should ı add something ? May you explain sir ?
Message 11 of 46
(3,685 Views)
Manually setting the scope is just physically touching the buttons and turning the knobs. Just extremely basic knowledge of the instrument. Something that someone should know before diving into the deep end of programming.
Message 12 of 46
(3,680 Views)
But  in this time what should ı do average count probe ? When don't connect nothing this average count probe, it automatically takes #Averages 8  value.
What should ı cannect this probe sir ?
Message 13 of 46
(3,671 Views)
You aren't making any sense to me. You are getting s timeout with the default of 10 seconds. Changing it is trivial and is something you should know when you manually configure the scope for a higher number of averages.
Find a fellow student that can give you a brief tutorial on scopes. I would think a freshman in an electronics major would do it for a six pack.
Message 14 of 46
(3,661 Views)
Sir ı just wonder what should ı connect "Avarage  Count " ?
Message 15 of 46
(3,657 Views)
Also attachment vi is not working ? I increased timeout max value.
Message 16 of 46
(3,651 Views)
When ı try manually in attacment vi also ı made timeout max , scope not accept my value. For example  when ı try # Averages 256, scope not accept 256 averages, it is accept 8 averages. Smiley Sad
Message 17 of 46
(3,652 Views)
Forget about your code for a little bit.  Can you manually (pressing the buttons that are physically part of the scope) set up the scope and get the waveform you expect?  If you can't do this manually, you are just spinning your wheels with the code.
Message 18 of 46
(3,638 Views)
I'm giving up suggesting the same thing. Doesn't seem to pay attention.
Message 19 of 46
(3,628 Views)
I tried manually several time. Sir time out max value is 2^32 . Also ı use max Avareges #32.  I think ı should use for loop because ı should expand  time out max value.
What do you think about that ?
Message 20 of 46
(3,626 Views)
