Average excel column
Hi everybody!
I m reading different excel files and take data in to array.
Now i want to average each excel column separately.
Is there any method in Active x so i can directly average excel column?
or i want to average the array?
How to average the array?
Jenilia D
Canberra
Australia
Jenilia D'souza
(3,240 Views)
Hi
If you have the data in a 2D array in LV, you can easily use Mean.vi.
Just have a look at the attachment.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,233 Views)
It can be simply done in programming Smiley Very Happy so why do you need a activeX for it,add the numbers in the array by putting it in a loop and divide it by the total number of elements .Smiley Wink
vicky
(3,232 Views)
