Average majority of element of array
Dear Friends,
As beginner user of lab view struggling with this problem which I can explain it by an example
my array:
 8 8 8 7 8 9 9 7 24 14
I would like to calculate the average of majority of elements which is 8
any help or hint would be highly appreciated
(4,115 Views)
@arvin1947 wrote:
Dear Friends,
my array:
I don't understand.  The average of the majority of the elements, the way you describe it, will always be that number!
Bill
CLD
(Mid-Level minion.)
(4,113 Views)
Maybe it would help if you gave us the expected answer.
Bill
CLD
(Mid-Level minion.)
(4,110 Views)
Hi Bill,
My expected answer is 8 in this case
thanks
(4,085 Views)
My expected answer is 8 but in this case it is not, I would like to be able to delete out range numbers
(4,084 Views)
Accepted by topic author arvin1947
It sounds like you're looking to calculate the mode? If so, LabVIEW has a built-in VI found at Mathematics > Prob & Stat > Mode.vi
GCentral
(4,067 Views)
Use Mode.vi as suggested by cbutcher and Provide the interval as 0 and use multi model if multiple numbers share same amount of repetition.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,035 Views)
