Average value for waveform chart
Assuming you are taking samples at fix interval let's say 1 sec. for 1 hour then first index is 0 and last will be 3600.
You can corelate your time 0:30 will be index 29 and 0:45 will be 44.
If interval is not fixed and data is coming at any time then you may make an time array for incoming samples and search for index values in this array.
Labview user
Message 11 of 15
(2,836 Views)
Oesen,
If you are going to set the chart so that all the data you will be acquiring will be on the chart, then selecting the segment will not have the issue I discussed above.
Setting the scale minimum and maximum does not change the chart history length.  If you are taking one measurement per second, there will 3600 points after 1 hour.  The default chart history length is 1024.  Changing the X Scale Multiplier does not change the history length.  To save all 3600 points you need to change the history length manually.  There does not seem to be a property node for changing the history length.
The attached VI demonstrates this.
Lynn
Message 12 of 15
(2,829 Views)
Hi johnsold
What if i write the data to a spreadsheet file, and then read the data from that file with a waveform graph, and then find the average value with cursors. Can i use that procedure ?
Best regards
Oesen
Message 13 of 15
(2,824 Views)
Accepted by topic author Oesen
Oesen,
Yes, that should work fine.
Lynn
Message 14 of 15
(2,822 Views)
Thanks for the help johnsold 🙂
Best regards
Oesen
Message 15 of 15
(2,814 Views)
