Average
Average,
Is there, or is it possible to make subVI with
- One input
- One output
- The output gives the average / mean value of the last n (constant or
variable) value's on the input.
- It's no problem that the first n output values are incorrect.
- It's a problem when the input is a subVI in the loop or program.
Thanks Paul
(3,364 Views)
Paul;
Unless "n" is a constant value or depend on the number of elements on the input array, you need an extra input to tell your subvi where to split the array.
You can explit an array using the "Split 1D Array" vi, located in the Array menu in the functions palette.
You can use the "Mean" vi located in:
Mathematics -> Probability and Statistics
With this, certainly you can do what you want.
Regards;
Enrique
www.vartortech.com
(3,364 Views)
"You can explit an array..."
Sorry, I mean split...
www.vartortech.com
(3,364 Views)
