Averaging Power Spectral Density using DAC Assist
I am trying to do a very specific measurement that, I believe, should be very straightforward. I am trying to measure the voltage from a photodetector from a laser hitting the back of a reflective Atomic Force Cantilever where the resonant frequency is around 30kHz. The detector voltage signal V(t) is captured using a National Instruments PCI 6251 at 1MB sampling rate and 10MB # of samples. My VI makes use of the DAC Assistant to acquire the signal and run the data through the "convert from dynamic data" to the VI express "Spectral Measurements". I take the Power Spectral Density of the signal but it is still noisy (I understand I need to average a decent amount of signals) and I see other peaks that I don't expect to be there. When I used an oscilloscope I could see a peak that I wanted after averaging many FFT signals.
I am not sure what to do at this point. From the literature it seems pretty straight forward to do this but I am unable to do this effectively. When I tried averaging the signal in Labview it didn't change the spectra. Do I need to store the PSD of each as an array (or as anything else) and compute the average of the stored data that can be plotted? Maybe I should do some filtering if Aliasing is a problem? I am new to labview and have been trying to understand the how to use it effectively but it has been very difficult.
Any help would be greatly appreciated
(2,794 Views)
Hi there cj291,
Here's a neat example to demonstrate the use of the FFT Power Spectrum and PSD VI. Beware, it requires LabVIEW Full Development System. With it you can see how the averaged Power Spectrum results change, and change the averaging parameters to explore various FFT averaging and weighting modes. Maybe you will find it useful!
Success!
(2,735 Views)
