Avoid Coercion dot
Can you tell me how I can go about resetting the INPUT cluster in the attached VI when you enter into step 3 of the program and avoid the coercion dot that is currently in the program?
hiNi.
(3,060 Views)
The booleans in your cluster need to be switch action. Latch action booleans are not compatible with value properties.
(3,058 Views)
