AxioCam MRm Zeiss driver
Could you share the SDK from Zeiss?
Best regards.
Message 11 of 24
(4,067 Views)
A stipulation for getting the SDK from them was to sign a nondisclosure agreement.  But if you contact Zeiss customer support they will put you in touch with the people in Germany who will kindly share it with you.
Message 12 of 24
(4,063 Views)
Peabody_bass I am following up with what I had emailed you previously.  In the mean time, be sure that you are using the mrfw64 driver and dll.  The MRM rev 3 has specific drivers separate from rev 2 and separate ones for 64 and 32 bit.  I don't remember having trouble with camera initialization.  The tricky part for me was when I started trying to acquire images.
Check out the image in this post:
http://forums.ni.com/t5/Machine-Vision/Do-I-need-to-change-Imaq-Create-VI-or-related-VIs-for-a-1394a...
Be sure that the pointer you use in Mcam Acquisition is set to a value and not a pointer to a value.  You might know this but I had quite a time figuring it out.  Good luck
Message 13 of 24
(4,061 Views)
Hi JJsword,
I never received an email from you, but I did reply to your PrivateMessage.
I was able to get initialization to work.  I was using 'mcam64.dll' instead of 'mrfw64.dll'.
I am having an issue with acquisition, though (just like you mentioned).  I was already using a the GetPixelPointer function, and passing it as a value.  But I'm getting error 6, ''Internal memory error (image size) happened during acquisition'.  Thanks.
Message 14 of 24
(4,052 Views)
Try setting a ROI that is 1040 by 1376 ( I will have to check the exact numbers and repost). If the image is too big for the buffer you will get an error and too small will cause the next line to start showing up on a previous line.
Message 15 of 24
(4,047 Views)
Try putting 0,0,1376 and 1040 (assuming no binning) into a cluster and call McamSetFrameSize. Your image buffer should be just big enough to hold the data.
Message 16 of 24
(4,040 Views)
What representation do you use for those values (I32, U16, etc)?  I'm assuming you pass it as 'Adapt to Type' and 'Handles by Value'?
Also, when I retrieve the resolutions from the camera, I get [1388,1040], not [1376,1040].  I'm guessing it's not a problem though, as long as the values are divisible by 4.  Thanks.
Message 17 of 24
(4,032 Views)
The pImagedata calling McamAcquisition that is put into the Image array are unsigned 16 bit integers U16.  That pImagedata is set to a Numeric type, Unsigned pointer sized integer, and passed as a Value.  Setting it to Adapt to Type and Handles by Value will cause it to crash.  Not sure why but I just confirmed the crash with the MRM rev 3 with those latter settings.
The 1388 by 1040 is the reason for setting a ROI that is 1376 by 1040 with McamSetFrameSize.  You have no other way (that I know about) of adjusting the array size so your Image array that is set with IMAQ SetImageSize is either too large (causing a staggared image that spills over to the next line) or too small, causing a crash.
Message 18 of 24
(4,024 Views)
One correction is that while the Image array is and allocated unsigned 16 bit array, pImagedata itself is a 32 bit pointer variable containing the address of the array, which I have set to U32.  Sorry for the confusion.
Message 19 of 24
(4,015 Views)
Hi jjsword,
Thanks for the help.  I'm was able to set the frame size to 1376x1040 (confirmed by calling 'GetCurrentFrameSize').  But I still get the same error (#6) when acquiring.
What resolution do you set to LV Image Buffer?  What value do you use for the 'AllocatedSize' input for 'AcquisitionEx'?
So we are on the same page, here is my DLL call configuration for 'AcquisitionEx':
int32_t McammAcquisitionEx(int32_t cameraindex, uint32_t pImageData, int32_t allocatedSize, int32_t pCallBack, uint32_t UserParam);
Are you using the same?
Message 20 of 24
(3,992 Views)
