Axis 2100 Network Camera
It has dealt no with network camera Axis 2100?
I am complicated with activex.
(3,414 Views)
If I understand you correctly, you would like to acquire IMAQ Images from a network camera that has an ActiveX control. This is possible if the control outputs images as 2D arrays. If so, you can use the IMAQ ArrayToImage.vi to convert these 2D arrays into IMAQ Images. From there you can take advantage of our IMAQ Vision functions.
Kyle V
(3,414 Views)
