Axis jumps when initializing (BAD)
I am doing some motion control using a PCI-7344 control card and a third party servo motor drive. It is configured for velocity mode. I am initializing the 7344 card in a Labview program and more often than not there is a big jump of the axis when I do this. This jump is causing shaft couplers to slip and now my position is off. There must be a way to eliminate this jump. I have tried to adjust the tuning parameters so the servo is well damped with very little overshoot. This seems to have no effect. How to I do a soft initiazation that won't wring things off?
Perry
(3,045 Views)
I found the problem. The jump occurs when a limit switch that enables the axis is tripped. Evidently enabling and disabling the axis causes it to jump eventhough it is not being commanded to move when this happens. I am dealing with another problem that causes the motor to move off zero when it is commanded to go to zero.
When I reset the encoder counts to zero and then command the motor to go to zero, the motor moves off zero. The position vi is in absolute mode.
Perry
(3,021 Views)
Actually, initializing the axis does cause a problem if the motor is freewheeling when it happens. This is probably a problem unique to servos in velocity mode. So I am finding that I have to disable the axis then initialize the axis then enable the axis.
Perry
(3,002 Views)
