Axis multiplier in Waveform Graph will autoscale limits when autoscale is disabled
I have a waveform graph with both autoscale and loose fit disabled on the Y-axis. If I change the Y scale multiplier using a property node, the upper and lower limits of the axis are automatically changed, even though autoscale is disabled (seen in LV2019 32-bit).
Y multiplier = 1Y multiplier = 1  Y multiplier = 0.49, Y axis limits changedY multiplier = 0.49, Y axis limits changed
My expectation was only the waveform would be scaled in the Y axis, and not the axis limits too.
Y multiplier = 0.49, limits unchangedY multiplier = 0.49, limits unchanged
The simple workaround is to rewrite the upper and lower limits after writing the multiplier property, but I just wanted check that the observed behavior is by design and not a bug.
(3,054 Views)
Accepted by topic author Dataflow_G
The scale doesn't auto scale. It's just the scale numbers that change.
The exact same data is visible. So, no scaling is happening.
In your case this might not work, but the opposite behavior, as it is now, might be useful just as often (it is for me).
So, read the scale min and max, set the scale multiplier and the min and max...
(3,017 Views)
Hi G,
Why do you expect the scaling of the waveform plot when you change the properties of thy axis?
You change the (multiplier) property of the axis - and that multiplier is applied to the axis labels - just as expected (by me)…
(3,011 Views)
