[Axtive X in a panel] "control could not be loaded"
Hi I do an experiment in robot control. The setup is shown in the attached file.
The problem occurs at the client site, the panel is loaded through the web page except the two ActiveX objects."control could not be loaded" was appeared rather than the objects.
I searched the previous posts but I still unable to solve the problem at the client side.??
Should I download the SDK for the activeX object at the ???
(2,778 Views)
What active X controls are you using and what operating systems are on both systems?
Verne D. // Software R&D // National Instruments
(2,753 Views)
Thank you for your reply
on the server side: the operating system is windows vista, while the client side use windows7.
Also i need to notify you that when I load the html on the server site the 2 activex are loaded in the panel ( but the axtivex responsible for transfere the camera video is still black, and no any images are displayed in this activex box.
(2,719 Views)
I'm not sure I'm getting the full picture yet. Would you mind posting an example VI that uses the ActiveX control that won't load?
(2,696 Views)
