B K sound measurement
Does anyone have experience using LABView in conjunction with B&K Input Modules 3050-A-060 or 3050-B-060?  If not, any thoughts about the possibility of developing a driver would be appreciated.  Normally a B&K software suite called PULSE is used to interact with this hardware which is connected via a CAT5 network cable.
Thanks in advance,
Jack
(3,006 Views)
I used B&K sound before, but I only the software pulse with it.  I didn't develop any labview app or driver for it.  If you have the B&K modules command manual and protocol,  you should be able to develop a driver for it.  Why don't you use the PULSE software?
Kudos and Accepted as Solution are welcome!
(2,989 Views)
Thanks for your input.  To answer your question on why, my company has made it a goal to standardize on LABView for all data acquisition and control programming.  So anywhere it is possible we are developing LABView solutions.  The advantage would be not having to learn and re-learn how to use PULSE software.
(2,975 Views)
I think that's a great project, since PULSE is pretty hard to use.  It think it could be done, you  just need to have the command manual.
(2,965 Views)
