BIG ASCII string to HEX string
Hello guys,
I know that is already a lot of posts regarding this issue, but I couldn't find exactly what I need and also couldn't manage to solve it myself...
I need to convert a string with ASCII characters to a string containing HEX representation of these characters.
What I did was:
Apparently it works very well, but only for a limited numbers of characters, defined by data representation of the 0 constant (U64). It allows me to convert only 8 ASCII characters, as you can see on the image below:
So, it converted from 0 to 7, but not the remaining characters (8 and 9).
Any ideas??
Thanks in advance!
(4,554 Views)
Accepted by topic author henriquegpo
What is the data type of the constant wired into the typecast.  My guess is it is a U64.  So it will only typecast the first 8 bytes of your string to a number, then you are doing hex on those 8 numbers.
Use the function String to Byte Array.  Or you could also typecast where an array of U8 integers is wired into the typecast function.
(4,545 Views)
Omar
(4,541 Views)
Raven and Omar,
Both solutions worked!
Thank you a guys, I have a lot to learn in labview programming.
Best regards!
(4,380 Views)
