08-26-2005 08:29 AM
08-26-2005 09:05 AM
The first thing to understand is that the DAQ Assistant is designed to quickly get you acquiring data. It is not however, designed to acquire data quickly. Since you converted it to a VI, you can look inside and see what I mean. Every time it's called, it does a Create Channel, Timing, Start Task, Read, Stop Task. Everything except the Read should only be done once. Look at the shipping examples for DAQmx on how to do an acquisition more effeciently. The most pertinent one may be Cont Acq&Graph Voltage-Int Clk.
Second, using the build array can be very ineffecient. With each iteration, your array gets bigger and bigger. The longer it runs, the bigger it gets and the more time that the LabVIEW compiler takes to allocate more memory. If you know how long the VI will run, you can allocate the size of the array before your start and do a Replace Array Subset function. For a fixed number of acquisitions, you could also use a for loop and just wire the data out of the for loop. The auto-indexing feature of a for loop will automatically create an array of all acquisitions. A while loop also can be made to auto-index. Since it appears that you want to save the data, you could also save each acquisition as it occurs. Look at the example called Cont Acq&Graph Voltage-To File(Binary). At the rate you're acquiring, that should not be a problem.
Lastly, if you want to control how often the acquisition occurs, you need to put a wait statement in your program. This can be either Wait (ms) or Wait Until Next ms Multiple.
08-29-2005 12:50 AM
08-29-2005 01:51 AM
08-29-2005 10:21 AM
08-30-2005 12:13 AM
08-30-2005 07:39 AM
I just wanted to comment on one thing Dennis said:
"The first thing to understand is that the DAQ Assistant is designed to quickly get you acquiring data. It is not however, designed to acquire data quickly. Since you converted it to a VI, you can look inside and see what I mean. Every time it's called, it does a Create Channel, Timing, Start Task, Read, Stop Task. Everything except the Read should only be done once. Look at the shipping examples for DAQmx on how to do an acquisition more efficiently. The most pertinent one may be Cont Acq&Graph Voltage-Int Clk. "
While he is correct that if you want to 100% optimize your application then use the DAQmx examples, the assistant is not the best for you, but not necessarily for the reasons Dennis mentions. For a continuous app if you look at the VI which is created you will notice there is a First Call primitive wired to a case structure which calls the Create Channel, Timing, etc only the first time the Express VI is called. On subsequent calls those VIs are not called and therefore that is not what is slowing down your program. In fact it looks just like a DAQ example. One of the slowdowns is the conversion of waveform data to the LV dynamic data type, but this is not a huge slowdown. I would look at the building of the array in your program as Dennis points out as the major culprit.
08-30-2005 08:36 AM
If you have several channels at different settings why not create global channels and a measurment Task in Max Explorer.
I've recently been using a system which reads about 60 channels at 500 scans a second, I read 100 scans (or more if there's a backlog) 5 times a second. The 100 scans are averaged for each channel and saved in a slow log file. Ten of the channels are saved at the full scan rate of 500 scans/s, writing the data to a fast log file each 0.2 s, both the fast and slow logs are csv files. But as stated earlier don't use a build array, this will definately slow down the system.
Ian S
08-30-2005 11:18 AM
