BK Precision 891 DCR Function
I downloaded the driver for the BK Precision 891.
I have tried every function available.
every one of them worked except for the function I needed. Which is DCR.
I am getting Error 102.
Has anyone had experience with this equipment?
Thank you
Thank you
(1,389 Views)
Signal level should be set to1 VDC, not 1 VRMS for DCR mode?
-AK2DM
(1,374 Views)
how do I change this to VDC?
(1,365 Views)
here is the driver
(1,362 Views)
Looks like their driver did not include full support for the DCR function, you will probably have to compose your own command string to send to the Write function, the level command for DCR is 1 VDC, refer to pg 23-24 of the manual linked below.
https://assets.testequity.com/te1/Documents/pdf/bk/891-um.pdf
-AK2DM
(1,301 Views)
Accepted by topic author DragonSnow
i disabled this and it worked.
(1,294 Views)
