BK9121 Driver Timeout read error
Hi, I downloaded and installed the BK9121 driver from NI but when I tried to use the example code I get error -1073807339 occured at VISA Read in BK9121A.lvlib:Initialize.vi->BK9121A Output DC Volts.vi (HEX 0xBFFF0015, timeout expired before operation completed).
It seems to be related to wait for DSR which simply times out, *IDN? also times out. I did test the instrument with direct VISA (intitialize, write, read) and MAX Soft panel and they work but the driver from NI does not....what to do?
Message 1 of 1
(2,743 Views)
