BLE GATT
Hi Erik,
I have not recieved any messages at all, if you write an email in to NI support, I will assign the request to myself and get in contact with you that way, as there seems to be some problem with forum correspondence.
Cody
Message 11 of 17
(2,116 Views)
Dear Cody,
i wrote to the support email adress. ^^
Anyway my old support request ID was 2515272. Hope you can find all the information there.
Looking forward to hear from you.
Cheers
Erik
Message 12 of 17
(2,108 Views)
HI There,
So, did you solve the problem?
Could you share the solution of this for me?
I'm in same trouble in cody.
Thank you,
Best Regards,
Kim
Message 13 of 17
(2,018 Views)
After almost a year now, I'm in the same situation.
Can someone post a solution or an update on the BLE/Windows/DLL issue?
Thank you,
Randy
Message 14 of 17
(1,913 Views)
Could anyone share a sample code to open communication with a blutooth device with the above GATT service dll ?
Message 15 of 17
(1,640 Views)
I've used the Nordic BLE functions called from Labview with success.
You'll have to have an understanding of the functions that are in the Nordic DLLs. (assuming it's Nordic that you are using)
Message 16 of 17
(1,636 Views)
Hi Randy,
I am trying to communicate with a SHT31 Eval kit(Sensirion Humidity Sensor) using a Surface tablet.
Android Code for same can be found below:
https://github.com/Sensirion/SmartGadget-Android
If I get a starting point with a template like your Nordic blutooth VIs, I will try my level best to port them for my application. Blutooth LE devices seems an uphill task without java scripting knowledge. I would appreciate if you could share what you have for Nordic devices.
Message 17 of 17
(1,634 Views)
