BMP/Image to vector/array conversion
I am trying to take a simple black/white image and use the pixel information, such as black? yes position: 1,0 example if I have an image like:
o    _
_    o
I would want something like (1 0) (0 1) out with that being 1 for o and 0 for _ ( or black and white) and then also the positions so maybe ((1,1) (2,1))... this is so I can design a pattern and then reproduce this with a mirror for a possible, very simple photolithography application.  I know this isn't very well worded I am still devising a better idea but any ideas?
thanks
anthony
(3,248 Views)
I'm not sure I understand you fully, but how about this?
The VIs on the left can be found in the picture palette if you have a version that isn't the base version.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
(3,245 Views)
That was what i was looking for, I haven't had to deal with images yet.  Thanks for the advice too!
Anthony
(3,236 Views)
