06-11-2013 10:05 AM
I am trying to read data from the BNC 2120 device into Simulink. I also need to use SIT to communicate the data output from the model with LabVIEW.
I am currently using Matlab 2011a and LabVIEW 2012.
The problem I face is that the hardware is not recognized when I use the data acquisition toolbox.
Please let me know what can be done to fix this problem.
Bharat
06-12-2013 04:10 PM
Hi Bharat,
The BNC 2120 is a connector block so it may not show up in the Data Acquisition Toolbox. What will show up is the DAQmx device you have connected to the block. You can find a list of supported DAQmx devices here, https://www.mathworks.com/products/daq/supported/ni-daqmx.html .
I hope this helps.
MATLAB® and Simulink® are registered trademarks of The MathWorks, Inc.
