BOOLEAN expression for fluctuating signal
I want to create a BOOLEAN expression to return a TRUE for a signal that is increasing and FALSE for a signal that is decreasing. Any idea how this can be done?
Message 1 of 8
(4,985 Views)
You didn't mention what the 'signal' is. Here is a VI that may do what you want.
Message 2 of 8
(4,970 Views)
Hi Lavezza,
Thanks for the effort. My signal that I have in mind is a triangular waveform. I tried out your suggested vi and basically it enable me to do the job already. Thanks
Message 3 of 8
(4,958 Views)
take the derivative of the signal and test for positive.  the simple method is to get a derivative is to subtract Sig(t) to Sig(t-1).  if your signal is noisy, lost of High Frequency you can ater a moving average of a few points and then take a derivative.  There are lost of Waveform functions for filtering and analyzing a signal.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 4 of 8
(4,947 Views)
take for example my signal is a triangular wave. How can I program it to stop operation after let say 20 rounds of complete period
Message 5 of 8
(4,875 Views)
Assuming you use a while loop, you just check the iteration terminal. Presumably you can calculate how many points are in your 20 periods worth of data.
You can also use a FOR loop and feed it an autoindexed array of 20 periods. Attached is a quick example (LAbVIEW 7.1).
Message 6 of 8
(4,862 Views)
I am thinking of using the peak/valley detector. Let say after 20 detected peaks, it'll send the TRUE command to stop the while loop.
I cannot know the number of points in my signal, thus using the iteration number is not possible.
Message 7 of 8
(4,858 Views)
Just use the '#found' output of the Peak detector vi, and keep a track of this in each iteration of the while loop. Once the cumulative value equals 20 (or more) stop the while loop
See attached jpeg for an idea of how this could be done.
Regards
Hannah
NIUK & Ireland
Message 8 of 8
(4,839 Views)
