BP transfer function
BP learn and Bp eval blocks, which transfer function is used? Can this transfer function  be changed ? How?
(5,336 Views)
Not knowing what "BP Learn" means, I turned to Google and got lots of hits for Boston Pizza (and an Oil Company).  Sorry I can't help ...
Bob Schor
(5,303 Views)
Apparently those functions are part of the LabVIEW Machine Learning Toolkit
I installed it but I can't find anything useful in the documentation (I only found this: https://forums.ni.com/ni/attachments/ni/7324/229/3/Machine%20Learning%20Toolkit%20User%20Manual.pdf , page 3)
I also tried the documentation of the new LabVIEW 2017 Analytics and Machine Learning Toolkit but couldn't find the function there.
I would suggest digging here, maybe you will find what you need 🙂
Another solution is to just see what is inside the VIs - they are not locked from what I see.
(5,300 Views)
i'm pretty sure BP means back propagation, but with the effort taken for the question, i didn't check on that
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(5,293 Views)
Thank you for your interest 🙂
(5,255 Views)
