BPSK and ML
Hi everyone
I need to Implementa two blocks as show in the picture. first problem is input That must be an array of U8 bit stream Which I can not generate.
second is as show in the picture, I should implement the ML (Maximum likehood), BUT I get confused.
thank you for your help
(3,266 Views)
it sounds there is no one .
Cruzzluz, Altenbach .. where are you Nights
(3,241 Views)
Hi uni-pixel,
Do you mean that you would like to implement these mathematical operations within a vi?
Shazil M.
CLAD
National Instruments UK & Ireland
(3,097 Views)
