BUG: 1D Array Sort is not sorting Array of Classes and Array of Clusters contain Classes
I vote that we either implement an overrideable "sort value" method for all classes (default empty string) or we simply ignore classes when sorting.
Having LV peek at the private data behind the scenes makes me a bit queasy.  This could be manipulated to find out class data contents.....
Just my 2c.
Shane
Message 11 of 23
(2,240 Views)
I don't have a problem with the security issue, really, but I still maintain that this is meaningless. To illustrate, take Ben's example, but simplify it - suppose we have just one class with no elements in its cluster, how do you sort it?
___________________
Try to take over the world!
Message 12 of 23
(2,224 Views)
The screenshot in the initial post illustrates why this use case isn't meaningless.  The user has some class data bundled with a numeric and a string.  He's using the numerics and the strings as keys to sort the class data.  He's probably going to unbundle the sorted classes after this operation.  I do this kind of thing all the time, I just haven't needed to with LV Class data as the data I need to sort by keys.  But I might someday.
Message 13 of 23
(2,212 Views)
I see. You're talking about the middle image in the original post.
I can see why you would want that to work, but it should pointed out that the logic for breaking the wire in the rightmost image applies in the center image as well. The fact that the class is third in order and will probably not be used for sorting does not mean that it will NEVER be used for sorting. I would say that IF this was changed, then classes should have no effect on the sort and should be returned in the same order they were in the original array.
___________________
Message 14 of 23
(2,206 Views)
Sounds good to me...just treat the LV Classes like they are all the same value, for the purposes of sorting.  Anyway, I included a link to this thread in the CAR, so these ideas should be visible to the eventual CAR fixer.
Message 15 of 23
(2,196 Views)
Yup, ignore the classes when sorting as I said previously.
I don't think anything else is really viable.
Shane.
Message 16 of 23
(2,191 Views)
Just be aware that if you do that, NI will probably get support calls with a title very similar to the current thread: "BUG: 1D Array Sort is not sorting Array of Classes - I have only a numeric in my class cluster, but when I try to sort an array of classes, nothing happens".
___________________
Message 17 of 23
(2,172 Views)
Well that's a goot time to teach the user about the meaning of private data and encapsulation and why it's NOT a bug.
Shane.
Message 18 of 23
(2,163 Views)
Something to that effect should be added to the Sort documentation when this issue is resolved.
Lynn
Message 19 of 23
(2,141 Views)
This has less to do with encapsulation and more with the class-is-a-data-type concept. To sort any data type, you need some sort of logic and the problem is compounded when you need to sort "non-matching" data types.
___________________
Message 20 of 23
(2,124 Views)
