BUG Block diagram cleanup fails completely? Generates very bad results
Well, still living with or without the BDCT.  It's a hit or miss basically.  Sure is a lot of extra work to manually pull/tuck wires...but...I've been doing it.  It happens on very simple BDs too.
Another clue that sometimes happens.  If you have NOTHING SELECTED in your BD and use the BDCT, it may not work, or simply ignore the BDCT button click, however, if you select the first structure of your BDCT it will "some times" work.
Still hope this problem gets resolved.  I love the BDCT when it works, it saves me so much time.  BDCT when it works is better faster code.
Message 51 of 52
(558 Views)
Finding out more about this behavior.  Any time you use a DISABLE DIAGRAM STRUCTURE, this increase the chance of failed BDCT.
What I've been doing now to avoid this problem, is when I want to DISABLE Part of my code, I use a CASE STRUCTURE and make it false.  Then the BDCT works.
There is a bug with BDCT and it's repeatable...but...I don't think anyone cares about the BDCT.
Message 52 of 52
(525 Views)
