03-10-2020 02:42 AM
So, i have an existing RabbitMQ-installation that i use in a project.
I installed LV and the RabbitMQ-service didn't start and i could no longer access the web-UI.
Trying to get it to work again i've noticed the environment variable RABBITMQ_BASE is changed to "C:\ProgramData\National Instruments\Skyline\RabbitMQ"
Resetting that the service starts again, but the management UI is still broken.
This was in LV2020 beta but i suspect it affects more versions.
/Y
Solved! Go to Solution.
03-10-2020 10:02 AM
Seems like a similar issue here. Does the proposed solution help?
03-10-2020 11:20 AM
Well, this is rather the other way around. The LV installation looked like it worked fine, but my previous (existing) RabbitMQ stopped working. Removing RabbitMQ also removes Web service, but i'll see if it makes a difference.
/Y
03-11-2020 04:13 AM
Thanks for the link @thols, by uninstalling the RabbitMQ-component in LV i could reinstall my old one and get the other project running. I don't quite know how this will affect LV, but currently that's not a big issue. LV doesn't play nice in this case. 🙂
/Y
03-11-2020 06:47 PM - edited 03-11-2020 06:47 PM
Unfortunately, you cannot have multiple version of RabbitMQ on the same system. FlexLogger, LabVIEW, NXG, SystemLink and many other NI applications moving forward will leverage it for interprocess communication between our applications and services, so you will probably need to host your other application on a different system or modify your existing usage of it to leverage the RabbitMQ configuration NI is using.
03-12-2020 01:31 AM
